Dear friend, if your Mep counter is 0. you need to cable process to reset your Mep counter . after that your Blackberry 9800 unlock . and no need to unlock again. use any Gsm sim card in your Blackberry 9800 torch.Good luck.
You can't unlock with codes..Try some softwares to unlock.
Please be careful when using free unlock services as you may run the risk of having your phone hardlocked.
Hardlocked, as a technical term, means that your phone cannot be SIM unlockedanymore.
A phone can be hardlocked for so many reasons. It could be:
The last reason happens when you have used up all the unlock attempts.
To check your phone it is being hardlocked, read through here : What's A Hardlocked Phone? What We Know So Far
Try Blackberry Revive bbrevive.com. Your problem will be solved irrespective of your Blackberry model, already solved several hardlocked Blackberries with 0 mep and it takes less than 24 hours.
Shipping down your phone will not be required, it will be resolved remotely by putting you through various steps. The technical personnel connects remotely to your PC to complete the process.
bbrevive.com. Hardlocked Blackberry Revive Solution
skype: bbrevive,
gtalk: bbrevive
