SOURCE: laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only.
If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge.
Under normal conditions, they should measure a couple of percent higher than their rating.
You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
SOURCE: Can't find many of the drivers for G60-230US for
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
SOURCE: my hp G60-230US won't turn on
REMOVE YOUR BATTERY AND TRY RUNNING IT OF DC POWER THAT WILL TELL YOU IMMEDIATLY IF IT IS THE MACHINE OR THE BATTERY
SOURCE: HP 550 Note book will not start
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE to restore it back to an earlier date when laptop was ok. THEN LATER ON PUT THE BATTERY BACK IN.
SOURCE: laptop is not booting and beep three time
i have this problem... my laptop still doesent work but to switch it on just rap it in towels or clothes or even put under ur pillow and leave it there for half an hour keep on doing this and it will switch on thanks
