Question about Frigidaire FAD504TDD Dehumidifier
Just bought this unit and it wont drain out the hose just keeps filling up the bucket.
    Brigadier General:
  • 4,736 Answers
When this happens with a brand new unit, there are a couple of things that can be causing it:
The drain hose/garden hose you're using is to long. It should not exceed 48" in length and must slope down and straight to the floor drain.
A piece of packing material or debris is in the hose concector and inner tubing. To remove this clog, turn the unit OFF & unplug it. Then Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% . Allow the unit to run, while you monitor the hose end for water flow. Be patient, as it may take 5 to 10 minutes to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helps you to troubleshot & solve the problem. Thanks for choosing FixYa.
Posted on Sep 23, 2011
4 Suggested Answers
SOURCE:
  • 417 Answers
SOURCE: Bucket fills up instead of water flowing out hose
There must be a blockage in the hose causing the water to back up and flow into the bucket. Try pushing a flexble peice of wire through the hose to unblock it.
Posted on Oct 17, 2008
  • 24 Answers
SOURCE: Hose line is no longer draining the unit, bucket fills instead
Sounds like the connector hoae came off inside the machine . Look up inside the machine where the bucket would go and you should see where the hose attaches to the condensate drain . It might have pulled off .
Posted on May 10, 2010
  • 4736 Answers
SOURCE: our new unit will not
Despite it being new, it sounds like either the hose is clogged or to long (no more than 5 feet in length) or is kinked. The other may be, that the hose connection on the dehumidifier is clogged.
After checking the hose for clogs and length and finding nothing. The clog is in the hose connection tubing. To remove the clog do the following.
Turn the unit OFF and unplug it. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though, carefully insert the Zip Tie into the hose connector tubing, Continue to push it in, until you reach a bend in the tubing. You will gingerly have to work the Zip Tie past this bend, until the Zip Tie either bottoms out or you run out of usable Zip Tie. Then pull the Zip Tie out slowly, while rotating (twisting) it. This will dislodge any clogs. As you reach the inserted end, be prepared for some water to follow.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jul 01, 2011
My dehumidifier bucket fills and wont drain thru the drain hose
* Brand and model# needed for specific instructions.
*** following is for the Kenmore dehumidifier ***
* Check your warranty and call for service.
*** The following is for information only ***
* I had one of these dehumidifier. I've used both the drain bucket by itself and well as the hose attachment.
* the bucket has a hose cap at the bottom to allow a typical garden hose to be attached. Remove the cap and attach the hose.
* If you want to use just the bucket then you will need to remove the garden hose and re-cap the bucket. Otherwise the water will just drain on the floor. You can find a replacement cap at any hardware or garden shop.
* There is a sensor switch under the drain bucket. This senses if there is a bucket present and it will turn off the unit once it's full of water.
*** The bucket must be present for this dehumidifier to work ***
* You must place the bucket in the right position for the unit to come on. The attached hose must move freely up and down to prevent the bucket from being weighed down and turning off the unit as it thinks the bucket is full. Lifting the hose a bit up and down will give you an idea if it's too heavy.
* Final; there is an adjustment knob in the front to determine how dry the air you want. I've used this unit to dry out wet carpets in a room so it's set at max and usually takes about 1-2 days to dry out a room (in Hawaii with 60% humidity). You will need to set this up and adjust it for your purpose.
Aloha, ukeboy57
I found the following vids on you tube;
https://www.youtube.com/watch?v=VhLv0xR9-Ag
https://www.youtube.com/watch?v=EmWuaIG8fS8
https://www.youtube.com/watch?v=XOh4BztkIEo
https://www.youtube.com/watch?v=Zb2rj-xWE9A
Jul 03, 2018 | Dehumidifiers
Why would the system keep running, all the time, filling up bucket, then leaking onto floor? What is my next step?
There is supposed to be an auto-shutoff float in the bucket to prevent overfilling of the bucket. You have either removed it or it is defective. The fact that it runs constantly has more to do with the humidity and the setting that you have the unit set to, Obviously there is adequate humidity in the space or the bucket would not fill. You need to look for, find, and repair the shut-off float, or, if possible, some units allow you to connect a drain hose either to the bucket or directly to the unit to drain the water to a drain. If you choose this option, remember that the hose must remain lower than the top of the bucket or it will not drain properly and the bucket will still overflow.
Jan 23, 2016 | Dehumidifiers
How to make unit drain through hose, instead of filling bucket?
Assuming you have a hose connected to the bucket for drainage, it is necessary that the end of the hose be lower than the top level of the bucket or the bucket will fill before the hose drains. I see many people who have their units on the floor and run a hose up into a sink and wonder why the bucket fills. Gravity works.....if you cannot find a lower place to drain the water then you must raise the unit up on a table or stand of some sort to get the bucket higher than the drain.
Sep 16, 2015 | Friedrich 25 Pints Dehumidifier 115v power...
Doesn't run, turn on or anything............I think it has died. Bought in 2004. Any suggestions? 65 pint/2 speed. Hose connection to drain, no reservoir needed.
the full bucket switch on these models goes bad, o.k.,i know,you said its hooked to a hose to the drain so the bucket never fills up,but,seriously,test the "bucket full" (in the upper right hand area of where the bucket installs) shut-off switch,as this will kill one of these units if it goes bad as it carries all the units power through it at all times,i replace many of these every season,if this switch goes bad it shuts off the entire unit
Apr 16, 2011 | Woods WD25G Dehumidifier
Will not drain out of the hose i have to keep emptying the pan i thought it was suppose to drain out of the hose to keep running
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
Mar 21, 2011 | Whirlpool AD35USS Dehumidifier
Haier HDN655E - water does not drain out of hose
check the hose connection,when new these units have a knock-out plug where the hose goes so if your only going to use the bucket and not the hose it wont run out the hose connection
Aug 01, 2010 | Haier HDN655E Dehumidifier
May 04, 2010 | Whirlpool AD50USS Dehumidifier
Do i need to disable the collection bucket to attach a drain line to my Matag dehumidifer M7DH45B2a? Or does it keep a full bucket and drain the overflow to the tubing drain?
No just connect the hose and open the hole to the unit to drain and return to usauge. it will fill to the drain opening and drain.
Aug 23, 2009 | Maytag M7DH45B2A Dehumidifier
I have the hose hooked up to the back but it keeps filling the tank and shuts off when it's full ,how do you just use the hose to drain
I believe you have to put a plug to drain that drains into the tank ,then it can only drain out the hose.
Jul 14, 2009 | Maytag M7DH65B2A Dehumidifier
Frigidaire FAD504TDD Dehumidifier Logo
211 people viewed this question
Top Frigidaire Dehumidifiers Experts
Alan Chouinard
Nestor Dede
Level 1 Expert
A Hoffman
A Hoffman
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
