Question about Dimplex DFI2309 Electric MidSize Heater
Motor makes a humming noise I was sent a new motor but NO instructions on how to replace the motor...do you have instructions? thanks.....
    Brigadier General:
  • 4,736 Answers
The instructions on how to replace the Flicker Motor Assembly can be found starting on Page 15 in your Owner's Manual. In case you have misplaced yours, I have included a link to it, that you can download & print for future reference, should you have to replace any more parts in the future.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
I hope this helped you and thanks for choosing FixYa.
Posted on Sep 23, 2011
SOURCE:
Should motor make humming noise - instead of making no noise - if starter Capacitor is the only thing faulty ?
Not always, just replace the cap to start with. Sometimes they howl an other bearing make a noise.
Jul 23, 2017 | Cars & Trucks
Blower motor
Make sure the capacitor matches with the new motor
Dec 09, 2013 | Weather King 10AJA6001AH Air Conditioner
Why is it whining and humming?
Sometimes a louver on the squirrel cage comes loose maybe from taking it apart...hand test every louver. You may find that you need a new one.
Jun 29, 2012 | Emerson Lennox Ducane Armstrong Furnace...
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
I have a Craftsman Commercial 1/2 HP Bench grinder. When I turn it on It just hums. It doesn't turn. Can you tell me what is wrong and which part I need to change? Thank you, Marlan PS: I have misplaced...
The motor has a high spot on the armature causing the motor to stop rotating. The humming noise is the fields full of current which is making the armature to react to make this noise. For the money purchase a new bench grinder which is an easier fix than dumping money into your old one here
May 05, 2010 | Grinders
Pump makes humming noise, but does not flush.
hi sounds to me that it is blocked these pumps are for waste only not paper etc
Nov 16, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Dishwasher wont go into cycle mode and hums
No model and brand name .
the way you mention look like the main motor jammed and making the humming noise click out on overload then the humming noise stop and after a while it will humming again and continue like that until you switch off the machine. If the dishwasher is old I would recommand you buy a new one instead of changing the motor.
God Bless have a nice day Dickson
Jun 30, 2009 | Dishwashers
Dryer motorstuck.. itself.. work'sometime.. but stop with the humming soung the is some smoke .. please solve it..
hiMotor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.
The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
Sep 13, 2008 | Kenmore 63942 Dryer
Horrible noise
it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
Apr 24, 2007 | InFocus ScreenPlay 4805 Multimedia...
Dimplex DFI2309 Electric MidSize Heater Logo
517 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Naveen Sistla
Naveen Sistla
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
