Check your cables from aerial, dish, PVR
are connected properly. Also with remote press Input/AV button continuously to see the various input screens like antenna, AV1, AV2, HDMI 1-3 etc
Hello Jacques,
This type of failure on this plasma is due to a defective IC that is mounted underneath the black heatsink located on the Ysustainer board. In order to isolate this failure to the Ysustainer board, I would suggest to check the fuses at location FS2 and FS3.
Here is more info for in regards to the Ysustainer board: REPAIR SERVICE FOR EBR31872801 YSUS BOARD FOR FLASHING DISPLAY TV NOT...
SOURCE: 42PC3D 42 in. Plasma Television: SCREEN ON 42 IN. PLASMA LG PICTURE LOOK DARK YOU C...
how dar is the picture ?
i can help you if you have more details
SOURCE: Problem with the LG 42PC3D
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
If you haven't used tv before you will need to scan for channels. Select Menu, Setup, Auto and wait until it's finished scanning
