Health & Beauty Logo
Posted on Sep 23, 2011
How to use ap ap solution for dandruff!? - Health & Beauty
Jill Mercy
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Oct 08, 2019
Jill Mercy
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
11
Questions
0
Helped
1251
Points
27
You should know that this product works by increasing the amount of moisture in the skin but it also will shed the skin cells. I've never applied this before, but it seems to me that this product is a little bit aggressive and I don't want to have those side effects I've read about because my skin is too delicate. As for me, I will first try using some anti-dandruff shampoo I read about on https://www.canadapharmacy.com/. But, I'll also appreciate if someone shares their experience using ap ap solution.
tip
Helpful Remedies For Dandruff
Remedies by Ayurvedic Doctors can be the most ideal approach to treat such an issue. Distinctive Ayurvedic cures have been helping individuals to dispose of dandruff in an extremely normal manner with no sort of reactions. In this way, let us examine some splendid manners by which Ayurveda can support you.
List of remedies:
-> Camphor with coconut oil
A modest quantity of camphor with coconut oil has been helping individuals to dispose of dandruff for quite a while. Utilizing this blend will assist you with getting free of dandruff and furthermore chill off your scalp.
-> Lemon with coconut oil
Lemon is an exceptionally normal fixing which is utilized to treat dandruff. In this way, in the event that you blend lemon juice with coconut oil and apply it on your scalp then you will dispose of dandruff in an exceptionally regular manner. Apply this oil routinely before you clean up and you will see some stunning advantages.
-> Neem leaves with lemon
Neem is one of the most significant Ayurvedic treatment. Take some neem leaves and transform them into a paste and blend this with some lemon juice. Apply this glue on your scalp and keep it for at some point for around 30 minutes. You will see splendid outcomes inside possibly 14 days in the event that you apply this regular.
-> Fenugreek seeds
Fenugreek is likewise a splendid Ayurvedic fixing, whenever utilized the correct way, can give you some astonishing outcomes. Splash some fenugreek seeds medium-term in water and afterward transform it into a glue. After this apply the glue on your scalp for around 20 to 25 minutes and wash it off. It won't just assist you with getting free of dandruff yet in addition increase the quality of your hair follicles.
-> Amla paste
You may have heard that devouring amla is valuable for your wellbeing. It is a splendid portion of cancer prevention agents and furthermore gives your digestion a genuinely necessary lift. Be that as it may, amla can likewise enable you to dispose of dandruff viably. Make some glue out of Amla powder and apply it on your scalp for 15-20 minutes before you wash it. This will assist your scalp with detoxifying and expel all the dandruff.
So these are the absolute best ayurvedic ways which can enable you to dispose of dandruff from your scalp. Ayurvedic cures don't have any sort of symptoms and in this manner, you can pick any of these procedures to have a without dandruff scalp.
on Sep 13, 2019 • Health & Beauty
Massengill usage for hair growth
It sounds crazy...If someone tried it, let me know if you saw any effect. As for me, I use more traditional ways to combat dandruff. First of all, I always try to moisturise the skin of my head. Therefore dandruff will most likely not appear and hair will be stronger. Then, if I need I also buy medical shampoos. But it happens when the situation is bad. You can read the guidelines on https://www.canadapharmacy.com/ when to use those shampoos. And the last point, I take supplements for hair and nails when I feel the deficiency of vitamins.
tip
Fight hair fall with natural ingedients.
In summer we sweat a lot. Our head is no different. Due to excessive sweating hair may fall and can create a concern for you. Here are 5 remedies you can try.
1. Mix 5 teaspoon coconut milk, 1 teaspoon Indian gooseberry (Amla) juice, 1 teaspoon water melon juice, 1 teaspoon tender coconut water and 1 teaspoon lemon juice together. Apply this mixture on the scalp and hair. Keep it for 20 minutes. Then wash it off with cold water. You can prevent hair fall.
2. Mix cucumber juice, tender coconut water, raw mango pulp, Indian gooseberry paste, fenugreek seed paste and egg yolk together. Apply this mixture to your sculp. Keep it for some time and wash it with normal water.
3. Due to dandruff hair may fall. The day you put anti dandruff shampoo your scalp is free from dandruff. The same day you must wash your comb, towel and pillow cover with anti-bacterial solution like Detol, Savlon. So dandruff will not come back from these things.
4. Aloe Vera gel is very helpful for hair. It gives nourishment to hair in many respects. It is very easy to collect the gel. You have to just open up the thick leaf from one side. For one person 50 grams of gel is enough. You have to rub the gel all over your scalp and keep it for 10 minutes. After that wash your head with plain water.
5. Please, do not comb your hair when it is wet. Ladies should not make knot when the hair is wet.
on Jan 18, 2011 • Health & Beauty
tip
Homemade remedies for dandruff
If you do not clean your hair regularly then there is a possibility of dandruff. If you clean your hair too much then also the scull skin gets dry and may cause dandruff.
Incase you get dandruff then there is a wonderful remedy that you can prepare it at home. At it is economic also. Here is the recipe.
Take a small onion and extract juice of it. Take some hibiscus flower petals and extract juice. You can crush them and squeeze to extract the juice. Add freshly cut lemon juice, Neem oil, camphor to it. Apply the resulting solution to your sculp. You will get relief from dandruff.
OR
Mix Tender coconut water, lemon juice, ginger juice, mint leaves paste, brahmi (see picture) leaves paste, vinegar and little amount of camphor together. Apply this to your sculp. you will get relief from dandruff.
OR
Take 25 grams of fenugreek seeds and bake it well. Then crash it. Add 10 grams of camphor and crash the mixture to make powder. Add this mixture to 100 grams of coconut oil. Apply this oil to your scalp and massage well. Continue to apply this oil in alternate days. Your dandruff will go away in a week.
In addition to the above follow some rules. Always use herbal shampoo. Often put ginger paste and vinegar mixture to your scalp. Put 4 spoons of apple juice to your scalp 1 hour before taking bath. Eat food which has plenty of vitamin A and D. This will solve dandruff problem.
Brahmi Leaf
on Jan 16, 2011 • Health & Beauty
tip
Routine care at home to prevent the hair from damage.
  • Always keep your hair clean. It will protect them from dandruff, itching and hair lice, which ultimately results in hair fall.
  • Always use the shampoo and conditioner depending on your hair type. As for oily hair, you should use a shampoo, which is meant for specifically for oily hair.
  • Give regular massages to your scalp and hair with lukewarm oil at least twice a month. You can choose coconut oil, olive oil or almond oil for your hair. You can even mix these oil and apply the solution on your hair.
  • If there is dandruff in your hair you can mix camphor cubes in coconut oil to massage on your hair and scalp. It helps in reducing the dandruff.
  • Rub a lime on your scalp if there is dandruff on your scalp, leave it for 10 minutes and shampoo the hair. You should use medicated dandruff shampoo and oil to apply on your hair when they are suffering from dandruff.
  • Never comb your hair when they are wet. The roots of the hairs are the weakest when they are wet.
  • Keep the hair wrapped in a towel for a while then let them dry in natural air as excess usage of hair dryer too damages the hair texture and makes them weak and then ultimately they fall.
  • When your hair is falling, make a mixture at home containing Amla, Shikakai and dry neem leaves. Grind them together and apply this paste on the hair before washing them off for a while.
  • Whipped eggs mixed in curd and henna powder help in preventing hair fall.
  • Eat healthy diet including green vegetables, dairy products and fruits.
  • Drinking coconut water prevents the hair fall.
  • You can make oil at home for falling hair. Boil henna and neem leaves in mustard oil till the leaves get almost dissolved in it. Let it cool and then filter. Add few camphor cubes to it and fill in a bottle. Use this oil to massage on your hair.
  • Mixture of almond oil, olive oil and castor oil is equally good to prevent and stop hair from further falling.
  • Get your hair trim every month so that there are no split ends left.
  • Include at least 2 nuts in your daily diet. They help a lot in strengthen the hair.
  • Avoid using too harsh clips or bands on the hair. Never make hair too tight.
  • Protect the hair from dust and sun. Cover your head while going in the direct sun.
  • Apply hair pack on your head at least once in a month. It can be henna paste, curd, eggs or a combination of all.
  • Wash your hair every time you apply some chemicals on your hair in form of styling gels, creams, sprays or lotions. The harmful chemicals in them damage the hair and make them to fall.
  • If you have got the bald patches on your head then apply onion on the bald patch by rubbing it and then apply honey over it. Leave it for few minutes and then wash off.
  • Boil fenugreek seeds in any of the hair oil of your choice as coconut oil or olive oil. Restrain it and fill it in a bottle. Use this oil to massage on your head. Its very helpful in reducing the hair loss.
  • Eating iron rich fruits and food helps in preventing the hair fall. Include apples, beetroots and jagary in your daily diet. They are rich in iron so help to prevent your hair fall.
  • Eating amla in any form or drinking its juice too helps in preventing hair fall.
Follow these simple hair care tips and you can protect your hair from further damage
on Jun 30, 2010 • Health & Beauty
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
