Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
Eugene Galloway Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 42" Toshiba
Anonymous
Level 3:
  • Master 998 Answers
  • Posted on Sep 23, 2011
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
189257
Points
2955
Sir the problem of your unit is in the power supply it has already a bulging capacitor this bad capacitor is producing a low and unfiltered dc output.
I have a 42
If you see this bad capacitor replace it with same type and also try to observe the solder part of your pcb if there is a cold solder or loosed solder. ekcnoel_26.jpeg
If you see this resolder it but be sure not to connect separated pins if accidentally solder may caused much damage to the unit. Note before doing this be sure to unplug the unit. Good day and best regards.
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
this problem is from power supply section, check your power supply, change it with new one
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
2helpful
Toshiba 42hp66 without an image
Hello, You most likely have a bad Y sustain board! Part #'s are:
6871QYH053A, 6871QYH053B, 6870QYH005B, 6871QYH953A, 6870QYH105B.
Here is a link to the part you need!
http://www.discount-merchant.com/Y-SUSTAIN-PN-6871QYH053A-6871QYH053B-6870QYH005B-p/vizio-sku9506.htm
I hope this help you! Please feel free to give me a call or message me if you have any questions! Ask for Dave!
Thank you! :-)
Dave
1-503-432-9904
[email protected]
Flickering on any channel
I spoke to Hp tonight and was told that it is the ysus board, hope this helps. Ebay for 175
3answers
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Hitachi 42" Plasma 42EDT41
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!  Even if you decide not to attempt it, it gives you somewhere to start to tell a technician.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
