SOURCE: Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
SOURCE: Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
SOURCE: how to set date and time on aastra 5370
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
