There are basically two moving parts, the fan and the compressor. It more then likely is the fan. Be sure the air path is clean and the fan blade does not hit anything. If it is the compressor I would suggest getting a new unit and using that one elsewhere for the short time it has left.
Hi, When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt... Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
I see by my computer this is a UK unit made for UK climates.
I also found various web sites you can access for help with your unit. Please explore these.
God bless your efforts.
Hi! Your dehumidifier was made by Fedders for Maytag. However, Fedders as it used to be, not longer exist. It is now Airwell-Fedders. And they don't provide a download feature. However, you can call their Customer Service Dept
866-829-2440, and they may be able to email you a manual for your model. Be sure to have your correct model number handy, when you call.
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
