Springs on side under black screw, came out
Or, more helpfully, take them back out. Look in the hole, and you will notice that when you look through, the hole turns square. At the end the square, there is a little tab / square in one corner. It is generally *not* the same on both sides. You'll notice that the end of the piece you took out (the part that looks like a magnet) has one corner cut off -- so it's a rectangular box with one of the corners gone. Line up the missing corner of the piece you took out with the corner that has the little tab -- this allows the piece to get past the tab and be fully inserted. Reminder: check both sides, because they're not the same. And now, more helpfully, if you're curious, check out flea markets and get a broken Kitchenaid to take apart for $20 or so. Don't mess with your nice one. : )
