Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Take a syringe (no needle) filled with water, stick it in one of the little holes where the water goes in. expel the syringe, with about 10-20mL of water. Then turn on the dispenser, keep doing this. eventually it will suck the water out of the syringe. this bleeds the air out on first use. I had to do this with my BAR 32 machine, now it\'s fine.
take a syringe (no needle) filled with water, stick it in one of the little holes where the water goes in. expel the syringe, with about 10-20mL of water. Then turn on the dispenser, keep doing this. eventually it will **** the water out of the syringe. this bleeds the air out on first use. I had to do this with my BAR 32 machine, now it's fine.
it's supposed to say "expel" where the asterisks are above. don't know why the site edited this out.
Not sure if you've found a solution to this or not, but when I first got my machine, it did the same thing. I found that I hadn't pushed the water well down far enough. Once you've pushed it down far enough, a few air bubble pop up. I hope this helps!
