Nikon Coolpix 3200 Digital Camera Logo
Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Nikon Coolpix 7900 camera I purchased used. It came without the proper USB cord, so I purchased one separately. When I attached the camera to the USB port of my computer (and I've tried this on 3 computers), I get a "Power Surge on Hub Port" message, advising me to remove the device. The cable is fine; the computer and its USB ports work successfully with my other, non-Nikon, camera. It seems the problem lies with the camera unit itself. But I have no idea what to do about it. Please help! Stephen
Steve Allison
Level 3:
  • Master 5,569 Answers
  • Posted on Sep 23, 2011
Steve Allison
Master
Level 3:
Answers
5569
Questions
Helped
2002523
Points
16452
I'm afraid that USB port has been damaged and is drawing excessive current causing the error message. You are at least fortunate in that your computers' ports are protected since the camera could have otherwise caused damage. Using a basic multimeter one could probably measure across the pins 1 & 4 to determine if the camera's input is shorted; it should in no case measure less than 5-6 Ohms regardless of lead polarity. The current capability of a USB port varies by version but is between 500 & 900 Milliamperes.
Cannot get communication between PC and Cool Pix Camera cord in use fits camera and has USB on other end and it is attached to PC.
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
2helpful
Can I use 4 Gb SDHC card in my coolpix 7900?
No. The 7900 uses only SD cards, not SDHC cards.
1helpful
Driver download of nikon 7900 coolpix
Having gone five months without a response, I assume my suggestion to use a card reader solved the problem.
Require new battery lid for nikon coolpix 7900
just go to nikon.com and order the part you need. Joe
Viewing photos without time and date
Unfortunately the Nikon Coolpix 7900 does not have a 'display' button to take care of this. So you need to go through Menu to access Setup menu. Here you will get option to customize the display.
1helpful
Nikon coolpix 7900 service repair manual
You can get it here:
http://www.justmanuals.com/nikon-coolpix-digital-camera-7900-parts-service-p-22630.html
But its not free.
2answers
Coolpix 4300 needs driver & update for vista
this solution was originally written by a fellow expert dauphine
You can download PictureProject software from this address: http://chsv-soft.nikon-image.com/jpn/software/win/S-P2____-175WU-JPNJP.exe
That is the only Nikon software that supports Vista since your camera is "outdated".
Here is a quote from Nikon site:
  • We had released a Windows Vista-compatible version of PictureProject, v1.7.5, for use with the models listed below, and all models that followed. PTP (models supporting the PTP protocol) and Mass storage USB transfer options can be used for camera connection. However, the camera's transfer button can not be used to transfer pictures over a PTP connection. Set the USB transfer option to Mass storage to enable the camera's transfer button.
    Currently, the new Nikon Transfer and View NX will replace Picture Project as our new Image Transfer and Browser applications. These applications support the same Nikon products as Picture Project.
COOLPIX P4, COOLPIX P3, COOLPIX P2, COOLPIX P1,COOLPIX S10, COOLPIX S9, COOLPIX S8, COOLPIX S7c, COOLPIX S7, COOLPIX S6, COOLPIX S5, COOLPIX S4, COOLPIX S3, COOLPIX S2, COOLPIX S1,COOLPIX L6, COOLPIX L5, COOLPIX L4, COOLPIX L3, COOLPIX L2, COOLPIX L1/L101,COOLPIX SQ, COOLPIX 8800, COOLPIX 8700, COOLPIX 8400, COOLPIX 7900, COOLPIX 7600,COOLPIX 5900, COOLPIX 5700, COOLPIX 5600, COOLPIX 5400, COOLPIX 5200, (COOLPIX 5100), COOLPIX 5000, COOLPIX 4800, (COOLPIX 4600), COOLPIX 4500, COOLPIX 4300, COOLPIX 4200, COOLPIX 4100, COOLPIX 3700, COOLPIX 3500, COOLPIX 3200, COOLPIX 3100, COOLPIX 2500, COOLPIX 2200, COOLPIX 2100, COOLPIX 2000,COOLPIX 995, COOLPIX 885, COOLPIX 775.We do not plan to offer compatibility for COOLPIX 990 OR COOLPIX 880 connection to a computer with Windows Vista preinstalled. Use a card reader or card slot to transfer images.
Formatting a sandisk 4g to work with coolpix 7900 camera
sd hc cards are not supported by 7900, you will never can use such a 4gb card with this camera
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
