Hi classic11369...
Remove the old fuel line and filter from the tank...
You will insert a wire a little smaller than the diameter of the inside of the fuel line, and you will bend a small hook on the end of the line to fit over the fuel line (be sure to use a small wire) .
Lubricate the first 1 inch of fuel line with vasoline lightly...using your fingers or neednose pliers collapse the fuel line and insert it into the fuel tank, entend the fuel line long enought to go out of the fuel tank so you can reconnect the fuel filter...then pull some of the fuel line back into the fuel tank...
Please take time to rate me thumbs up
