NorStar M5316 Centrex Corded Phone Logo
Posted on Sep 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to be able to turn off the ringer on my reception phone for the 3 lines that are direct lines to the partners offices. How do I turn off the ringer to these three on the main phone so that it will ring in their office but not at my desk?
Anonymous
Level 2:
  • Expert 83 Answers
  • Posted on Sep 22, 2011
Anonymous
Expert
Level 2:
Answers
83
Questions
Helped
12029
Points
206
Take the help of epabx programmer who set ur device as per ur requirement
its a software programming nothing serious
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
1helpful
The ringer on the phone is too loud. I cant work in my office using another line.....How do I turn off the sound of the ringer on the phones.
Welcome to FixYa!
How to adjust or turn off the ringer volume on your handset.
Thank you for using FixYa. Have a great day.
Jas247
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
1helpful
I need to set the ringers to only ring at the two receptionist desks and not everyone else's offices. Please help! We have Avaya Partner 18D phones.
Partner ACS systems come with Centralized programming instructions. Most of them starting with Feature 00 Left Intercom twice and Right Intercom. When you dial an extension, the lights will be solid or blink according to how it's programmed and you press each button to turn on or off or delay ringing.
Your system administrator should have a book.
Carl
7helpful
How do I turn off the local ringer on my office phone, AT&T MLS12D
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
Press feature "00" to logout
Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Norstar Phones - Turn off ringer on phones
You have to go in to programming and set the phone in the shop to ring on line 3 only and the phones in the office to not ring on line 3.If you don't know how to go in to programming please inform me.
1helpful
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Can't turn ringer volume down
You can download a manual for this phone here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036632.pdf Pages 18-19 explain how to set the ringer volume.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
