SOURCE: Coffee maker side will not work.
check inside for broken or burnt connectors going to the heater element. these are normally slide in spade connectors.
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
SOURCE: Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
SOURCE: my Krups combo espresso/ coffee maker xp2070 will
Do you have power to the control module? Can you set the time or is the display completely dead? Mine was completely dead and I replaced the power module and the display/control module.
