Question about Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men
How do I set the hourly chime feature? - Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men
Place the bottom window in the Date mode. Then press both bottom buttons simultaneously. A small "bell" symbol will appear in the top window, upper left corner. Hope that helps.
Posted on Nov 01, 2011
  • Donald R Mateyka Nov 01, 2011
    Small correction---I meant to say that the small "bell" symbol will appear in the top window, upper RIGHT corner.
SOURCE:
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
How to set the alarm
These are the instructions posted on the Armitron website. I hope they help.
1. From Time Telling Mode, press 'B' twice to enter the
Alarm Mode.
2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
Alarm Hour.
3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
Alarm Minute.
4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
either Time Zone 1 or Time Zone 2.
NOTE: The Alarm is available in one Time Zone only.
5. Press 'A' to end set sequence.
6. Press 'B' to return to Time Telling Mode.
ACTIVATING THE ALARM AND HOURLY CHIME
1. While in Alarm Mode, press 'C' to activate the Alarm.
The Alarm symbol appears to indicate the Alarm will
sound at the preset Alarm Time for 20 seconds or until
'A', 'B' or 'C' is pressed.
2. Press 'C' again to activate the Hourly Chime.
"CHIME" appears to indicate the Hourly Chime will sound
every hour on the hour.
3. Press 'C' again to deactivate the Alarm.
4. Press 'C' again to deactivate the Hourly Chime.
5. Press 'B' to return to Time Telling Mode.
Apr 12, 2011 | Armitron Digital Sport #40/8095SIL Watch
How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
Jan 16, 2011 | Watches
I have a xonix watch that chimes every hour, how do I stop this?
I have just bought a xonix watch and had the same problem. To get rid of this annoying beep I just had to push the 2 bottom buttons simultaneously and it was gone :D
Sep 27, 2010 | Watches
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    How do I turn off the alarm on my Armitron watch?
    I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
    Nik.
    http://home.earthlink.net/~eldonenew/armitron.htm
    or
    http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
    Other People Are Reading
    Setting Date, Time and Alarm
    • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
    Using Chime and Alarm
    • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
    Backlight
    • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
    Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
    Our wall clock was not wound a couple of months ago (it is a chime clock that chimes on the hour and half hour with weights) and when we rewound it, everything works fine except that the chime is out of...
    You were not very specific about you clock description, Many of the German clocks were using auto correct features.
    You may not have this function.
    Move the hour hand to the correct hour.
    Hope this tip help you.
    R/
    David
    http://antiqueclock.clockstop.com/
    Mar 13, 2010 | Watches
    Can't set time on aqualite watch-field ranger
    I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
    The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
    Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
    Aqualite has 4 buttons:
    1) top right (we will call it S1 like this manual does)
    2) bottom right (this will be S2)
    3) bottom left (this will be S3)
    As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
    Setting the minutes, hour, date month and day:
    Press S3 3 times, or until the following are flashing in the display : TU and seconds
    Set the minute: press S2 once and advance by pressing S1
    Set the hour: press S2 and advance by pressing S1
    Choose from AM (A), PM (P) or military time (H)
    Set the date: Press S2 and advance by pressing S1
    Set the month: Press S2 and advance by pressing S1
    Set the day Press S2 and advance by pressing S1
    Press S3 to bring you to the time display
    Setting the chronograph:
    The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
    1. Press S3 (flashing in the display: SU, FR, SA)
    2. Press S1 to begin. Press S1 to stop.
    3. press S3 to return to the time display.
    Setting the lap time:
    The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
    In the time display.
    1. Press S3 (flashing in the display: SU, FR. SA)
    2. Press S2 to clear setting
    3. Press S1 to begin. Press S2 to stop.
    4. Press S1 once and S2 twice to reset.
    5. Press S3 to return to the time display.
    Setting the alarm and snooze:
    The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
    1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
    2. Press S2 once (minute will be flashing)
    3. Press S3 to set alarm and return to time display
    3. Press S1 to deactivate alarm
    5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
    6. Press S1 and S2 at the same time to deactivate the alarm at any time.
    To test alarm
    In the time display
    1. press S1 and S2 simultaneously for alarm test.
    Hourly chime
    Your chrono alarm sport watch ha the option of an hourly chime in the time display.
    1 Press S2 and then press S3 to activate hourly chime
    2. Repeat process to deactivate
    Jul 23, 2009 | Watches
    Dont know how to turn on hourly chime timex atlantis 100
    Set chime and Alarm on or off
    Press MODE to select ALARM
    Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
    Press MODE again and you are all set.
    Dec 28, 2008 | Timex Atlantis 100 77517 Wrist Watch
    Timex westminster anniversary chime clock doesn't chime correct number
    Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
    Oct 04, 2008 | Watches
    Jules Jurgensen 7996SS ( ) : Swiss Quartz Movement Watch for Men Logo
    185 people viewed this question
    Top Jules Jurgensen Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Tom Chichester
    Jim Dowell
    Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
