My kids left the freezer door open came home next day after work alarm beeping, removed the food meat still frozen unplugged for 2 hours, tried again next morning alarm comes on noyhing happens. how long should it take for the comp to start. and is there some kind of reset for the comp to protect it
Hello Captain rose,
Did you turn off the freezer and then pull the plug?
Try this again. Turn off the freezer then pull the plug for 4 minutes, plug it back in and turn it on.
Do you hear the compressor turn on?
It should only take 24 hours max. to get back to full temperature!
If this does not help and you hear no compressor, especially if it is an old freezer .
They may have burned out the old compressor by causing it to work 2 hours straight .
Rather than cycling off and on every half hour or so!
If it was an old freezer, so it means it was on its last legs and would have happened some time soon any way!
Here is an article I read abut the age of refrigerators and freezers.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
