SOURCE: coffee maker beeping
ugh! This just happened to me. washed it all out - let it sit - plugged it back in and now it beeps.. and ONLY beeps. whattup?
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
SOURCE: A couple of days ago, coffee maker turned it self
spoke w/ Cuisinart. Unplug unit for 1 hr, then plug back in, reset clock & Auto Off setting. This resets the unit back to the factory settings.
Testimonial: "great it works!!! thank you so much!!!!!"
SOURCE: my kitchenaid coffee maker gives
This problem occurs between 6 months and 1 year of these coffee pots. I have contacted customer service each time this occurs and have received a new coffee pot. Unfortunately, I am calling them again and again because the new coffee pots do not even last their warranty time and the ERR2 light again comes on and ruins my morning. I would not recommend this coffee pot. It is expensive and life time is not long at all. Customer service has been great but how many times do you have to return a coffee pot for Kitchenaid to get the hint that it needs to be fixed. Most consumers will get angry, throw it away and never buy the same one again. So, wake up Kitchenaid and smell the COFFEE!!!!!!!!!!!!!!!!!!!!!!!!! Fix this coffeepot. I am not the only one who has had this problem. Customer service @ 1-800-541-6390 Hope this helps. When they send you a new one they send you free shipping back for the old one and you use the box the new one came in.
