if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might be able work your way through the problem hope it helps
Please make sure that the external hard drive is plugged directly into a usb port on the computer and not a usb hub. Try disconnecting all usb devices besides your keyboard and mouse and external hard drive. Also see if this applies to your computer,see the link below. Please let me know what worked or give me more information, thanks for using FixYa
Getting Canon error codes usually means a trip to the Canon service center for a fix. There's a discussion in the DPreview forum regarding the same problem.
Apparently an E32 error code results in the camera powering off in exactly 60 seconds in the playback mode. It not necessarily affects just the G11 but other PowerShot models too.
Generally E-series error codes mean either a hardware or firmware issue that cannot be rectified by the end user. Hope this helps Positive feedback ALWAYS welcome :)
Error 401 means that you can't access a web site. To fully understand the error and how we need to try and help you fix this we need to know what HTTP Error 401 - you are getting.
Example: HTTP Error 401 - Unauthorized: Access is denied due to invalid credentials.
This is a problem with your communication bus of serial Hard Drive is you are using one.
I would recommend you to go to http://www.hirensbootcd.net/ download it and run recovery off it really a good software and works well. Let me know if any other problem arises.
