Kds K-92bw After about 5 min the screen goes blank..turning the unit off than back on the screen looks great for a while about 3 min than goes black..seems to be a caused by heat?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 190DTLB PCH 200 000 170DTLBMH PI 190DTLB ETL XPC 204...
This issue is most likely caused by a capasitor doing bad. There is no easy fix. It must be disembled and the power supply repaired. If done properly, it should cost somewhere between $ 50 to $125. But it may do it again as the Pwoer supply is a known issue for this monitor. Sorry.
