Computers & Internet Logo
Posted on Sep 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The external hard drive (1 TB) started making a noise last night. It was still working. Today it is still noisy and will not show up on explore at all.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 360 Answers
  • Posted on Sep 21, 2011
Anonymous
Expert
Level 2:
Mentor:
Answers
360
Questions
Helped
90713
Points
925
Your hard disk is damaged. The data you have on the hard disk could have been recovered when it started making noise. Looks like crashed heads of the disk. If it is under warantee, take it to the manufacturer for replacement.
Lee A.
Level 3:
  • Master 4,472 Answers
Lee A.
Master
Level 3:
Answers
4472
Questions
0
Helped
1083155
Points
12549
That means the hard drive has failed. You can try taking it out of the external hard drive enclosure and installing it into the computer internally to try and get some files off of it if need be but other then that the hard drive needs to be replaced.
thank you,
Lee
2answers
Have a 1.5. TB "Sea gate Free Agent - Desk". Used
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
It gets dected by the laptop and the light on the hard drive comes on but i cannot acces it as it does not show in windows explorer
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
2helpful
2answers
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
1 TB drive not turning on.
u mite need a replacement caddy if you are outa your warrenty period i would open it up an test the hard disc drive on another pc if it powers on u need to get ur self a another caddy type in google external caddy
My Free Agent 1 TB external has been dropped a few times. It seems to be working fine, but it makes a lounder noise than it used to when accessing files. Should I worry?
Yes. If the case has been damaged, imagine what happened inside the hard disk, where the tolerances are in microns. Start saving for a new one.
OS whont start whit WD 1 TB external drive.
You need to set your boot sequence in the BIOS so that it does not include external drives. Basically your computer is trying to load Windows from the external drive instead of its own internal one.
Your motherboard manual is going to help, if you can't manage it by yourself give me a link to your manual or tell me the model of your motherboard and i will show you what you need to change.
System not detecting my external hard disk
try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Trekstor DataStation maxi m.u 500GB stopped working :'(
This is probably a bad sector on your hard disk. Connect it up and try this:
1. Start > Run > type in cmd then click OK to get a command prompt.
2. Type in chkdsk e: /r (replace e: with the drive letter of your external hard drive).
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
