My printer was working a couple of days ago....i haven't touched it since and i tried to print something today and it says that the communication is not available and says to try disconnecting and reconnecting the printers power cable and USB cable or just restart your computer, but i did all of those and it still doesn't work. My scanner works and the printer will print a maintenance page, but it won't print anything from my computer. help me
SOURCE: Lexmark x5470
I have no CD in order to reinstall the USB device. The machine copies and now prints, but not scans!!
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
my printer says there is no communication available problem, and notify you when a new solution is offered.
I Have the same problem and seem to come on after my Window XP Pro was updated to SP3. Tried all the suggestion such as unplug switch on & off, re-boot and even uninstal and reinstal the Dell 964 Driver - still not good. I called Dell Phone support and was told that may be the SP3 (like same problem found in the Vista) but they cannot offer solution for now.
I instal the Dell 964 driver onto my Laptop (with Window XP SP2) and it is working fine. So for the time being I am using the printer with the laptop.
Suspect the SP3 update similar to the Vista. Will appreciate if there can be a solution by some expert.
Mario Yoong
the computer is saying "problem communicating with the printer" it told me to restart the computer, unplug and replug in the power cable etc. i did all that and it still does not work. i need help....
my printer says no communication
