Can be any of the below'
1. The connection between the screen and the unit maybe be damaged. You will have to change this.
2. The Driver IC/component driving the LCD maybe faulty. This will need to be changed.
3. The screen itself may be faulty;
a) bad connections
b) power supply
c) back lights (check closely if you can see any display)
d) the circuit in the screen has malfunctioned
in all this case you will need to see a professional repairer to have it diagnosed.
One of the logical solutions is that you try to shut down the pc , remove battery and cables & then hold the power button for 8 secs. That way, you can determine if the circuitry of the monitor is functioning. Otherwise , you need to contact MSI for repair..
