Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
Anonymous Posted on Sep 17, 2008
Sharper Image MIDI S1853
Red cleaning light stays on continuously after cleaning. What is the problem
Tim Babcock
Level 3:
  • Master 2,794 Answers
  • Posted on Sep 17, 2008
Tim Babcock
Master
Level 3:
Answers
2794
Questions
13
Helped
1128267
Points
7249
Could be a blade replacement needed but Sharper Image recalled the product.  Since it was proven in court that it wasn't effectively cleaning the air by Consumer Reports as well as EPA data.  As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
1 Related Answer
Anonymous
  • 28 Answers
  • Posted on Mar 09, 2010
SOURCE: Sharper Image Midi S1853 / NO BREEZE
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
SHARPER IMAGE IONIC BREEZE QUADRA RED LIGHT ON
I had one that had the "needs cleaning" light was on. After cleaning, the light stayed on. I checked around at the time and learned it couldn't be fixed, and it was out of warrantee. I believe that's why they stopped making them. Mine was just thrown away.
Sharper Image Ionic Breeze S1853 manual and trouble shooting.
replaced the lamp, the unit will not turn on.. If it has a fuse where is it located.
No air flow in my ionic breeze model S1853. Just the light is on.
The Ionic Breeze filters air from the room into the front vents and releases ozone through the back vents back into the air. Some models you can put your hand near the back of the machine and feel a slight breeze. If you do not feel any air or the light that is on is red, the magnetic plates that capture the dust, etc. needs to be cleaned. Don't forget to turn the entire unit, after removing the magnetic plates, upside down to clear anything trapped near the bottom.
Midi silent air purifier S1853 starting to make a crackling noise
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
4helpful
2answers
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
1helpful
My ionic breeze is off and won't turn back on.
my icoic breeze, midi, is off and won't come back on. the problem started right after i cleaned it, model s1853.
2answers
Ionic breeze midi
Sharper Image Ionizers are no longer supported because they have recalled since they were proven to be innefective for cleaning the air and can harm people with breathing problems.
Here is a link on the Chapter 11 report
Here is an EPA report on ionizers
Top Sharper Image Air Purifiers Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
