you can view your memory card in MY COMPUTER it comes in form of a removable device..
if nothing is happening then install proper drivers for your memory card..
Use the computer you are on to download the updated driver for the network adapter from the Toshiba Website. After you have the updated driver install it on the computer your having a problem on. Reboot the computer. If the problem is still there and you have a cable connected to the network connection and to the router, uninstall the network adapter from the device manager and reboot the computer. That should detect and install the adapter and resolve the problem. If it doesn't there is a problem with the network adapter and you will need to use the wireless of get a PCMCIA card to use for networking. Toshiba does use a replaceable Network card in some laptops, if nothing else above works and you don't want to get another card to plug in you may want to look into purchasing a new card from Toshiba to replace the old one.
After uninstalling it completely from the computer. When you plug in the adapter alone. You must get the "Found New Hardware" wizard. And nothing else apart from this. Only then it is correct. If nothing comes up at all, the device is dead or your version of USB might USB 1.0 or USB 1.1 which at times has issues. But if you see that wizard coming up, unplug the adapter and insert CD and run setup and walk through it.
Anyway, i ll recommend that you try this adapter on other NEW computer(laptop or desktop), just to check. I feel that this adapter would work on a new computer, maybe your computer's hardware specifications are old to support this device.
the graphics card in your pc maybe loose. the grapics card is located where you plug your vga/dvi connection in to the back of the tower. If you slide open the town you will see the graphics card in a brown slot beside the white PCI slots. check if it is secure.
Also the vga/dvi cable maybe faulty try a different cable.
Try to find out what the AGP voltage is on the motherboard. Some graphics cards use 1.5 volts and some use 3. If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
The x1800 is a high-end video card, and requires you to plug a power connector into the back of the card. If this is not installed, the video card will not work.
The card should have come with an adapter to change the standard hard-drive style 4 pin molex power connector into the 6 or 8 pin adapter for the video card.
See if this helps- Unplug the power adapter. Remove the battery. Plug in the power adapter. Attempt to power up. If that doesn't work- Power down. Remove the hard drive and CD drive, also floppy drive if you have one. Disconnect the cables to any external devices that you might have attached. Remove all of the memory cards. Replace 1 memory card in the main slot,only. This will reseat the memory card. Power back up and see if the system comes up to a BIOS screen. If not, and you have more than 1 memory card, try swapping to the other memory card. If BIOS comes up, start reinstalling each item (Hard drive first) one at a time, attempting to bring the system up after each item is installed. If the BIOS screen doesn't come up with everything disconnected, you'll need to disconnect the LCD screen (internally) and hook up an external screen. If BIOS shows up on the external monitor at this time, you have a bad LCD screen. If nothing in this process seems to work, you probably have a bad mother board. If you have any questions, please ask. Thanks! Ron-
