Pioneer AVH-P4000DVD Monitor Logo
Posted on Sep 20, 2011
No sound from ipod, usb or aux? - Pioneer AVH-P4000DVD Monitor
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1588
Points
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Jose Ignacio Colmenares Daal
Level 1:
New Friend:
Problem Solver:
  • Posted on Dec 11, 2014
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
1588
Points
Thanks a lot my friend I've the same problem and solved it with you answer... Awsome!!!
No sound when song is playing on my car stereo from ipod and my volume is loud enough to be heard
What kind of radio do you have? whats the model # of the radio? how do you have the ipod connected? Is it thru usb or 3.5mm aux jack? what model ipod do you have?
How can i get my ipod working through the USB connection on Kenwood CD Receiver?
It looks only the U359 supports the iPod.
On page 7 of the manual where the USB connection is explained, only this number is mentioned.
The numbers are to the left of the front picture.
The manual is still online.
I have a Ford Fiesta 2010 Hatchback Titanium model with the built in IPod/Aux/bluetooth connector. However my car Radio does not play Mp3 format songs but only Wav copied from windows media player. how...
ok, I haven't had the Wav only problem. Mine plays mp3's with no problem. as for the ipod, you have to have both the USB and the aux cable plugged into your ipod and car.
Feb 12, 2011 • GPS
How do i get my ipod to play through my cd player
There are two ways you can use your ipod through your HU.
1. You can use the Aux port (located in the rear of your deck), which you will have to run AUX cable and connect it to the Ipod. Mind you this set up won't charge your ipod. Have to change the source to AUX for sound.
2. Through the USB cable that is included with the system connect your ipod (From the looks of things USB connection is also in the rear of the deck). Hit the Ipod button and that should be all she wrote.
1helpful
2answers
Hi I just bought a brand new 2010 Ford Fiesta Zetec and I am having problems with the ipod connection via the usb, It all displays correctly, it shows the name of the song and how long the song has been...
You need an AUX cable in addition to the iPod USB cable. Use both cables, and you will get sound :)
The AUX looks like this: http://www.oriongadgets.com/images/3.5mm-audio-extender-male-to-male-1.jpg
1helpful
Hi do you know if the wharfedale ics 182 can play an ipod
You need to plug the iPod into the Aux socket, its on the front bottom right corner. Then you can switch by pressing "Mode" between playing either the CS - USB - SD - AUX.
To play iPod, select the "AUX" option.
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Connecting a Zune MP3 to the HT-X50
Get an Aux cable(about $10) and connect it to your Zune player and to Aux 1 on your Sound system. Make sure you change your function to Aux 1. Do not connect USB or anything else. That's working for me.
2helpful
2answers
Install
The ipod is supplied with a USB out cable and the head unit is USB compatible.It has a USB out.Connect the ipod "out "cable to the USB of the HU and switch over to USB mode on head unit. Switch on the ipod & play . As for erahs problem ,these pioneer head units have "switchable"AUX modes. with the power "off"(the HU power off)press the multicontrol at the centre for 3/4 seconds.options like "language etc will b displayed .AUX will be one of the options .select it ":on".now u can play your ipod through your head unit .
Top Pioneer Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
