I have a Lanier Transcriber Model V W-210. Today the fast forward and the reverse did not work. I could hear a motor sound, but the tape did not advance or reverse. The "listen" worked, as did the foot pedal for "listening." However, it did not back up the 2 words as I have it set for when I "stop" and "start." I could see the little turners turn for "listen" but they did not for reverse/advance. Help!
Re: I have a Lanier Transcriber Model V W-210. Today the...
This unit most likely has a broken rewind/fast forward rubber belt. This is a very common problem and is easily fixed if you can acquire a new belt. Any place that services Lanier equipment should be able to easily fix this problem.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Hi, Does the tape move when you press rewind or fast forward. If the tape moves for a few seconds then bleeps it sound like a sensor problem. If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward. Hope this helps.
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
yes I have two lanier voice recorders one left hand and one right hand one power supply real cheap do not use them any more . listed on ebay as lanier vw-110 standard cassette dictator. If you still need them. Thank you John
