Frigidaire GLTF2940ES Front Load Washer Logo
Anonymous Posted on Sep 20, 2011
Frigidaire FTF2140ES0 Front Load Washer lock indicator light goes off, but will not spin.
Dolf
Level 2:
Habit-Forming:
New Friend:
  • Expert 46 Answers
  • Posted on Sep 24, 2011
Dolf
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
46
Questions
0
Helped
10665
Points
110
Sounds like the electronic locking mechanism is malfunctioning. It is supposed to enguage before the high spin cycle. It is about a $20 part.
5helpful
2answers
My Frigidaire front load washer doesn't spin, it turns during the wash cycle, doesn't show an error code, but doesn't spin the load at all, it is model CLTF2940ES0. Is it something simplet to fix?
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
3helpful
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Need a restart code
Press & hold down the 'options' & 'select' buttons for over 3 seconds. And let me know. These are the buttons, but how long?
Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
1helpful
Washer not spinning
You're problem is probably the door latch assembly. This is a common problem on Frigidaire front load washers. You can find the part at your local appliance parts suppliers. If the door latch assembly is faulty, the washer will run through all of its normal cycles, but will not spin. Hope this fixes the problem for you.
5helpful
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Frigidaire Washer HELP
check for a sensor switch located underneath the door , its a safety device to ensure that door is tightly closed . hope it helps
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
