Refer to your service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
SOURCE: My leaf blower will not start, It keeps flooding
To start: turn the choke off, hold the throttle wide open and crank. You have a carb problem but this should get you going. John
Please rate if this helps-
SOURCE: homelite ut08107 will not fire. no spark at plug.
It may be the coil if there is not any spark. Or a wire could off at the coil. One more thing it could be is the spark plug wire may have came loose from the coil. These a few thing to check.
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
