P1299 --- Cylinder Head Over Temperature
Protection Active
That is an indication of an overheating condition & your
in a Fail Safe Mode
Most likely cause is low coolant level
The injectors may be disabled to protect the motor
You could be low on oil
Any number of things that are not correct & could
cause overheating
Leaves in the front of condensor,etc
A bad cyl temp sensor
Trouble Code: P1299
Cylinder Head Over-Temperature Protection Active
Possible Causes:
Cooling system has a problem
Engine coolant level is too low
A Base Engine problem may be present
TSB 10-29-1 contains repair help for this code (LS & T-Bird)
