hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder
should rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
threading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
