SOURCE: Disable receive mode on FAX-2800
NO the best solution is to turn fax machine off after hours
SOURCE: Minolta fax machine 2800
clean rollers with alcohol, it should pick up ( for a while) rollers will probably need changing
SOURCE: Changing date on Minolta 2800 Fax
You might try www.minolta.com to download a user manual. Otherwise you will have to scroll through the menus for SETUP
