Sewing Machines Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix new home machine it model No.731016401. model 360 manufactured by Janome its not sewing cloths. The thread is placed properly but when i try sewing it starts to break the thread. it turns in a tangled bundle of thread underneath shuttle.
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Sep 20, 2011
Level 3:
Answers
7365
Questions
Helped
1741652
Points
19451
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
also check the thread take up lever to make sure the thread has not come off of it cause that can make the machine jam up also
1helpful
I have an opportunity to buy a Janome 8002D serger. I don't know how old it is? What is it worth? Serial No.: 020050716 Lillian
Hello, Lillian -
I checked the instruction manual available for the Janome 8002D serger through the Janome website:
https://www.janome.com/siteassets/support/manuals/sergers/inst-book-8002deng.pdf
and did not find a date of printing on the manual (which would give an idea for the year/s the model was manufactured.)
I also found the following information on one of the Janome web pages:
(Quote)
For consumers looking to date an antique New Home sewing machine that was made in Orange, MA or Rockford IL, please click here. We are sorry, but no other New Home or Janome sewing machines can be dated.
The only information we can provide is a date of manufacture if you have the following information:
  • model number or style number
  • serial number
  • place of manufacture.
(End quote)
Source:
https://www.janome.com/en/support/general-support/faqs/
It looks like Janome still sells the model 8002D serger:
https://www.janome.com/en/machines/sergers/8002d/
As for the value of the machine you are considering purchasing, you can get an idea of the price/s sellers are asking by looking at online sales of that model sewing machine. Here are some links:
https://www.amazon.com/Janome-8002D-Serger/dp/B008L5FN4E
https://www.sewingmachinesplus.com/Janome-8002D.php
https://www.ebay.com/p/Janome-8002D-Mechanical-Sewing-Machine/99171774
Best wishes.
Need to know how to thread the new home model 654 sewing machine
You can get a manual for your machine here:
Janome New Home sewing machine instruction manuals
This video may be helpful. Machines usually thread similarly.
Janome New Home Special Edition
I have a Finesse new home 23 4 overlocker. How do I start the threading please.
A manual would be helpful:
Instruction Manual Janome Newhome 234
Even if you are unable to find a manual for your particular model, similar models usually thread the same or similarly. Just be sure to ALWAYS RAISE the presser foot when threading the machine so the thread will seat in the tension disks.
New Home Sewing Machine Manuals PDF and CD
Make It Handmade Threading Your Serger or Overlocker
My janome machine model 2001.doesnot work properly it thread is loose from down side during sewing ,sometimes work properly but some time while sewing it shows same problem i was cleaning with tooth brush...
I think you may have to careful clean everything and check you havn't dropped feed dogs or changed a setting. I don't really know what you mean by the foot getting stuck, but if the feed dogs ( moving part under the cloth) are down than the cloth can't move. Also, the pressure of the foot may be too high; this can also happen accidently while cleaning.
Get a manual ( sewingmanuals.com) and double check everything. Also, check there is no thread in the thread guides as this may have been your original problem. pull a thread towards to needle
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
