I accidently pushed a button on the machine and it deleted the process
to get it back on. It shows an 8 on window and It will not change any
of the numbers I push.
TRY THIS
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time. 2. Menu window will show "OKI USER" 3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button. 4. "Diagnostic Mode xx.xx.xx S-Mode is indicated. 5. Scroll to "NV-Ram initial" is indicated. Push ENTER. 6. Window shows "NV-Ram- Initial Table 1". 7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window. 8. Restart printer.
1.Turn machine on while pushing and holding
printer.
100%.
This process only deletes Miis so that you can add new ones, up to a maximum of 8.
Nintendo provides no advance notice that there is a limit of 8 players.
1. Go to the Wii Fit screen displaying all of your current Miis. 2. Select the Mii you want to delete. 3. Keep hitting the A button to go through all the extraneous jazz-ma-tazz nintendo inflicts upon us until you come to the calendar page with the options BODY TEST and TRAINING at the bottom. On this page you will see USER SETTINGS in the upper right-hand corner. 4. Select the USER SETTINGS page (push the A button). 5. Select DELETE USER DATA (push the A button). 6. Select YES to confirm that you want to erase the data.
I found this process very counter-intuitive as it required me to select the Mii that I wanted to delete, then act as if I were going to use this Mii, before giving me an option to manage the settings for that Mii.
The process for using a memory card to save Miis has been impossible so far. I purchased a Wii memory card, but cannot figure out how to bring the data from the memory card back into the Wii Fit game.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
