SOURCE: keyboard does not work
i would suggest starting over.. uninstall the drivers for the keyboard mouse and go download the new ones from the manufactures website and fallow the instructions. typically they want you to install the drivers first before plugging in the wireless receiver. i hope this helps.. good luck.
side note- if your having the same problem with 2 diffrent wireless keyboards. you might have some interference from another wireless device. i.e. cordless phone, cell phone. so you might troubleshoot that if the drivers dont work.
SOURCE: key board and optical mouse - PS2
muito simples:faz o download dos drives do teclado e rato da versão superior á que tens.depois vais ao painel de control+sistema+hardware,e fazes a actualização dos controladores.
VERY IMPORTANT:COPY ALL DRIVES TO DESKTOP.
copia para uma pasta,criada por ti no ambiente de trabalho,com 2 pastas 1 de keybord-1 de rato,copia entao os drives das duas versoes do equipamento,para essas pastas,
ao iniciares a actualização dos controladores ,indica sempre a pasta com os drives respectivos.
BOA SORTE
[email protected]
SOURCE: Logitech S510 mouse will not turn on
I am assuming since you need batteries that the mouse is cordless. If so you normaly have to sync the mouse with the receiver.If the keyborad and mouse came as a package it will only have one receiver.There should be corresponding sync buttons for these devices.
SOURCE: MS wireless notebook optical mouse 4000
Normal
0
Try disconnecting the Mouse Receiver from the
USB port and reinstall the CD software program. When
the program asks you to connect the Mouse Receiver to the USB
port, do so and it should work.
Hope this helps. Bud
SOURCE: how to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
