How to replace rubber door seal
when you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is,
if i have helped rate me,
