I appear to have locked my ds 2300 - I am not aware how. I have followed the instructions on page 31 of the maual, but when I get "lock" flashing on the display, and press "rec" as told, I do not get the next screen, but a message saying "read card only". Please advise how I can unlock my dictaphone!! Thanks.
Since you seem to be doing everything properly and following the instructions, I recommend that you contact Schlage for some technical assistance. Here is the contact information:
Schlage Lock Company Customer Service Department 2119 E Kansas City Rd Olathe, KS 66061 United States Customer Support Warranty & Technical Information: 1.888.805.9837
All the different lights you get on the dash of any vehicle, have
been there since 1980. That is 31 years. Nothing has changed
since then ,unless you were on another planet
Check for Codes
Diagnose System with OBD Malfunction
Repair system as necessary
If you did not purposely lock the files, must likely the memory is corrupted. You can reformat the memory from the menu. This will wipe out any files on the memory card.
That lock icon indicates a locked door, and if you can open your door with it locked, your door lock will need to be reset. Your instruction manual should have your reset procedure listed in back. But if your door IS locked, you will need to manually drain out the water before it will open.
Follow this instructions carefully 1 - Switch on your Nokia 2300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2300 would then display the message "SIM Restriction
Off" and will be unlocked!
The letter p
appears if you press the button star(*) three times quickly
The letter w appears if you
press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE (
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
3123526611) you need to enter is
the unique unlock code for your Nokia 2300
YES BUT TRY A SLIM-JIM FOUND AT SOME AUTO PARTS STORES. YOU WILL HAVE BETTER LUCK WITH IT AND DO LESS DAMAGE. FOLLOW THE INSTRUCTIONS ON THE BACK OF THE PACKAGE. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
