If the Jaguar makes noise and the ibanez doesn't, (assuming you are using a shielded guitar cable of reasonable quality with each guitar) I would suspect you have a either a grounding or shielding issue inside the Jaguar. if you bought your gear from a reputable dealer, they should be willing to fix the problem. If you bought the gear from a private seller, you'll most likely need to locate your own repair shop. Grounding problems are not hard to locate and I would expect an hour's bench fee. If it needs to be shielded, the cost would be higher due to material cost, but it should still be about an hour labor charge.
"Noise" is not a very good deescription... is it hum? is it static like? is it a buzz? Hum pickup by the pickups of guitars are common and some pickups are worse. If it is hum move the guitar away from magnetic sources like amps, motors, flourescent lights, dimmers... etc. Sme guitars have grounding problems and touching them varies hum. Also, do NOT let the guitar "hear" the amp as it can feedback at frequencies above your hearing even. Do some "sniffing" by moving the guitar and the orientation around the area seeing if you can find hot spots of noise to avoid.
