Zenith ZEN700 Remote Control Logo
Anonymous Posted on Sep 20, 2011
Samsung AK59-00123A remote to a M261VP vizio tv
Level 3:
Top Expert:
  • Zenith Master 76,851 Answers
  • Posted on Oct 01, 2011
Zenith Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007533
Points
237762
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Cho Gyi
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jul 22, 2020
Cho Gyi
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
2160
Points
Miguel Orama
Level 1:
Miguel Orama
Contributor
Level 1:
Answers
Questions
0
Helped
2160
Points
Got a ak59-00123A remite i need code for vizio tv modelo d40f-g9
I tried everything no luck. Any help appreciated
Vizio 26" 1080p 60Hz LED-LCD HDTV M261VP. The picture on M261VP went black. Power light is on, all cables are connected appropriately and router is functioning. Can this be fixed?
Question edited for a lot more clarity.
All question need full 'make model (what it is)' please.
Question moved from Computers to Vizio Television.
They can all be fixed, and this isn't a bad make. Our Television Expert @Larry should be along soon. You need a new board.
https://www.fixya.com/users/larry-bjerke
We are in a campground and our tv is on antenna. Wee want to change it to cable but don't have a remote with
ure cable remote shoud do it 4 u ie work tv look inside batt compartment on cable rem
No power or picture
hi there! John
Sometimes it is the cable, has to make sure is well pressed, second, cauld be a bad TV power assemble inside. RMS, required. third, some models has two power buttons one is below or side unit, and the other is on the remote , or front /side panel of the TV.
2helpful
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
My Vizio M261VP picture and sound went off last night but the power on white light on the corner of the frame kept blinking. Once before I unplugged this unit for a while and this fixed the problem. ...
If its something your comforrtable doing remove the back cover and test the power supply voltages, I think you will find at least one is missing, and in that case replace the power board
1helpful
My Vizio M261VP was purchased three weeks ago. A week ago, the audio on channels other than the digital HD channels are very low. For example, an analog channel or Netflix via the VIA the volume needs to...
I would return the Set ASAP! TV has a factory defect,take it back and get you another TV,
and If it happens to do the Same thing Then Company might have more then several TVs that must be returned to Factory.
I had a Friend of mine who bought a new Tv got it home it had a problem she took back 3 TVs and they all where doing the same thing.She just got her money back and went to another store.
But they did Offer Her Another Set from company.
146helpful
13answers
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
