Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
You purchased a used one, right? Could the spindles/mandrels/quills been replaced? If you know someone with a Husq. you could measure their mower. If it is all original, then I do not know if there is a way to lower, it would be as it was built and I have not seen anything that lowers the blades further within the deck except if there is another spindle that mounts and works that has a little different spacing. I have that problem with one of my decks and the difference is due to different maker of part. but my difference is no more than 1/2 inch.
deck is already down low as it can go.Im wanting a solution to lower blades.With deck lying on concrete slab blades measure 2 inches from ground.i dont want to run deck on ground as im cutting.thanks ,Preston
