I have a e-machine netbook em350-21g16i when i open the left side of lcd screen is be damage half is broken have line how i do
    Scholar:
  • 95 Answers
Hi, Needs new screen, Find a repair shop that will replace the screen or send it back to the manufacturer, Can be an expensive repair but ask if the the repair shop if they give free estimates first, Hope this helps,
Posted on Sep 20, 2011
SOURCE:
Samsung ue65js9505
There is no repair to a broken display panel. Contact the authorized service center for Samsung to get it replaced. The display panel to this TV is not available at open electronic spare part market. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 14, 2016 | Samsung Televison & Video
Dropped my laptop now 1 half of my screen is white and the other half is fine
Hardware damage
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the netbook.
The VGA port is on the Left Rear side.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Scroll down a little for the VGA Cable example.
NOTE* Color does Not matter. Usually it is Blue. Can be Black or White in color.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default the display should show on the external monitor.
However there are at LEAST 3 display options available;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key, (Bottom left corner of Keyboard), and at the SAME time tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F4 key.
Display good on the external monitor? Fine. Your graphics chipset is good. Problem lays within the Display Assembly, (LCD screen, Display Cover, etc), or the Video Cable.
Also posted in case you do not repair the netbook, or repair is set for a later date. This way you can at least use the netbook at home.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Video Cable:
The video cable attaches to the motherboard, in the upper left area near the left Hinge.
It then leads under the left Hinge, and up into the Display Assembly.
(LCD screen/ Display Cover, Display Bezel, etc. is the Display Assembly)
From there it connects to the back of the LCD screen.
(The Mini 110-3135dx has LED backlighting, and does not use a screen Inverter )
Just due to normal opening, and closing of the laptop, the Display Panel Cable, (HP for Video Cable), can be pulled on.
This means the connection of the Display Panel Cable, at the motherboard side could have been pulled loose, or at the LCD screen side.
It can also damage the tiny wires inside the Display Panel Cable.
From your description, it sounds like the Display Assembly was open, when it landed.
Display Panel Cable connections should be PHYSICALLY, plugged in to ensure the connections are tight.
A visual examination will NOT do.
Connection on the motherboard side AND -> LCD screen side.
If there is visual signs of damage to the Display Panel cable's sheath, also suspect damage to the tiny wires inside the Display Panel Cable. (Stretched/Broken)
Check the connections first. You can leave the laptop partially disassembled, and check, before putting it back together.
If physically checking, by trying to plug the two connections of the cable in, does no good, you have to suspect if the Display Panel Cable may be damaged.
A continuity check with a multimeter set to OHMs, and checking each wire in the cable, is the next step of the diagnosis.
You can take the cable down to the nearest 'Mom and Pop' computer store, and have the tech check it for a few dollars.
Or due to the price of a replacement you may just wish to replace, and see if that was the problem.
The HP part number is HP 607755-001.
HOWEVER, this is supposed to be for a kit that contains 3 cables.
1) LCD Cable (Display Panel Cable)
2) Webcam Cable
3) Power Cable.
[ Power Cable:
The DC Power Jack is the jack on the laptop, that you plug the AC adapter ( Charger ), into.
The DC Power Jack is NOT soldered to the motherboard, with this model.
Instead it is soldered to a cable of wires, and the wires end in a plug.
The plug is unplugged from the motherboard, and the entire assembly is replaced as a unit. (It's a Power Jack Harness, really)
DC Power Jacks get broken. This one will be easy to replace ]
http://www.aliexpress.com/store/product/LCD-video-Cable-for-HP-Mini-110-110-1000-110-1100-Laptop-LCD-Cable-6017B0207601-6017B0232102/908032_556440323.html
Check the part number on your Display Panel Cable, and see if it matches up to the one you are going to buy, is the best method however.
Display Panel Cable checks out OK, or you have replaced it, and it doesn't solve the problem, the problem is the LCD screen.
Again, in my searching of the LCD screen replacements, I found they all use LED lighting for your model. (Mini 110-3135dx)
LED backlighting as a rule now, does Not use a screen Inverter.
Could I be wrong, and your laptop does indeed have a screen Inverter?
Only you will know once you open the Display Assembly, and check the Display Panel Cable connection at the back of the LCD screen.
If a screen Inverter is used it will be in the Display Assembly.
A screen Inverter could easily have been damaged in a fall, and a bad screen Inverter COULD show the results you stated.
I say -> COULD.
I believe the Display Panel Cable connection may be loose at the motherboard side, and/or LCD screen side, or it may be damaged.
If not I believe the LCD screen is the problem.
To check the Display Panel Cable on the motherboard side, for this model, you have to remove the Top Cover. (HP for Palm Rest Cover)
This means the Static sensitive hardware components for the laptop, will be exposed.
This means you NEED to wear an ESD wrist strap, once the Top Cover is removed.
BEST method however is to just put it on BEFORE starting to disassemble. This way you do not forget, and have a Static shocked laptop, that is only going to be good enough for a DOORSTOP.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
The alligator clip needs to be connected to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
Pictorial guide that may help. Allows you to see someone working on an HP Mini,
http://www.insidemylaptop.com/replace-keyboard-in-hp-mini-1033cl-notebook/
Service Manual from HP Support (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4307901&
In the list click on -
HP Mini 110 and Compaq Mini CQ10 - Maintenance and Service Guide
[ Note*
On page 65 it shows the Wireless LAN cables.
Number 6 states,
"Disconnect the display panel cable from the motherboard"
It is actually referring to the Figure on the next page. Page 66.
And Number 1 ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 23, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
My daughter just dropped her acer aspire netbook. Only half of the screen is visible the other half is white and black with a line down the middle
Dropping the netbook will have probably broken the LCD screen.
There is no other way to repair the problem without replacing the screen itself. You can however use a external monitor and use the keyboard to toggle between the two screens.
I know this is probably not what you wanted to hear but unfortunately LCD screens are fragile so a good knock can crack them causing only one half or the part or the screen which is not broken to show. The backlight itself sounds like its working as there is still light showing behind the cracks.
Regards.
Mar 14, 2010 | Acer Aspire One PC Notebook
Fine white vertical line down the left side of the screen. It is always there I can't adjust out.
Does this white line show if the monitor is plugged into a different computer? If not, the graphics card in the computer might be bad or MAYBE the cable. If the line is still there on another machine, the monitor is broken. This likely means a fragile ribbon cable has been torn or damaged inside the monitor. It can rarely be fixed and is so fragile that most people further damage the cable when attempting to adjust it. Sorry about your luck.
Sep 14, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
Lenovo 3000 N100 Screen Problem
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 29, 2008 | Lenovo 3000 N100 0689 Notebook
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
Line on screen
It sounds like the actual LCD is damaged, i've seen some cases where it was a damaged cable going to the LCD screen but if the cable looks ok then it is probably the lcd screen.
Nov 09, 2007 | Fujitsu P55XHA40US 55 in. Plasma...
Computers & Internet Logo
37 people viewed this question
Alun Cox
