Dell Latitude 2100 (blcwwfp) PC Notebook Logo
Posted on May 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Dell Latitude 2100 netbook (small computer) was running slowly, then appeared to freeze. It would not shut off, so I was told to disconnect the power and battery. I did, and now, when I turned it on, the computer is just a dark screen. Every so often, it sounds like it's "sighing", but nothing is working. HELP! At the top of the keyboard, the volume controls (three) are all lit up) as is something that looks like a lock (with a 9 inside) and of course, the power button. Can you help?
Minister Ruland
Level 2:
Sergeant:
  • Dell Expert 445 Answers
  • Posted on Apr 24, 2019
Minister Ruland
Dell Expert
Level 2:
Sergeant:
Answers
445
Questions
0
Helped
127445
Points
810
It seems like the hard drive has stoped working and with out reading the harddrive the computer will not start. so replace the hard drive and reiinstall windows.
  • Anonymous May 05, 2019
    2 years late, boy I bet he looks like this waiting for you..
    seems,?. it can be many things.
    first is RTC coin cell bad and the big battery shorted.
    then HDD bad.
    but that sound, seems the owner never cleaned the PC ever, and is overheating.
    no? but we are too late, why not post to fresh posts say less than 3 months old
    there is no lack of posts here. ever.
3 Related Answers
Anonymous
  • 404 Answers
  • Posted on Mar 03, 2009
SOURCE: Dell D600 Lock Indicators and Volume Buttons not working
you need the dell's keyboard shortcut utility, dells hotkey and dells latest bios.
Anonymous
  • 253 Answers
  • Posted on Jun 20, 2009
SOURCE: Volume buttons and mute/unmute buttons don't work
First open the Control Panel -> Keyboard Layout. Look for the dropdown list for different keyboard models. Scroll to the Dell models and try e.g. the Dell Mulimedia USB Keyboard layout. Stop the GUI with Ctl+Alt+Return, login again and maybe your multimedia buttons will work now.
and for more info contact http://tinyurl.com/m7ghqz
If there is no keyboard layout that fits your needs, you may download the programs keytouch and keytouch editor, which are very helpful creating your own layout.
SConsolini
  • 8 Answers
  • Posted on Jul 13, 2011
SOURCE: the 9 lck key is
It's the Blue "Fn" key and the "F4" keys.
1helpful
Dell problem freezing
Not much to work with. Try shutting down unnecessary processes. It would be Helpful if we knew more, What were you doing when it froze? Perhaps it just needs some Cleaning and tuning up? Tow many running processes? Here are some Windows XP speed up tips: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer
Motherbourd fix
Check your battery, it may have run out of charge. Even when your computer is shut down, the charge still dissipates, although very slowly.
2answers
Dell Latitude D630 freezes
Try a System Restore and select a restore date before your problems started.
To get to the System Restore - Click on Start - All Programs - Accessories - System Tools - System Restore
Cant add my tv display
On my older dell latitude when using a vga cable to the tv you would go to computer's control panel and then "display" then settings. You should be able to click on the #2 monitor then apply the changes.
2answers
Dell latitude e5510 freezing vlc
my laptop is always goes hang after running any video file in VLC player. Pls reply what is the probable solution to run VLC player in Dell Latitude E5510?
How to fix my netbook
The hard drive is located on the bottom LH or RH side of the laptop.
The BIOS setting will give you details of the hard drive that is installed.
Yeah so about 3 weeks ago, my Dell D600 which is running XP Professional SP3, 2gb ram, an internal bluetooth, and using a usb wireless adapter, started to freeze at completly spontanious times. Everything...
Hi Chad,
It sounds like it could be 1 of 2 issues either the memory or your hard drive may be failing.
Please do the following:
Turn on the computer. When the DELL logo appears, press immediately. If you wait too long and the Microsoft Windows logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again.
When the boot device list appears, highlight Diagnostics and press .
Please choose the express test and post the results.
Mouse jumps randomly after 30 to 60min., appears to be over heating. latitude d820(laptop). how do i get to the fan. i have taken out all the screws on the rear (it is open partially but i did not want...
Dust is the enemy of a notebook/netbook/laptop computer, because it acts as a layer of insulation, preventing proper cooling.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job" through every intake/exhaust vent, to remove the dust.
Dell Latitude d600 series.The shut down after start-up
when your computer is freezes up then you download registry mechani it can improve your performance
11helpful
4answers
Dell latitude D600 problem
The flashing caps lock is an indication of a failed POWER on Self-Test (POST)
Remove the HDD, Battery, AC adapter, RAM and Modem
Press and hold power button for 15 seconds
Connect AC, see if you get any beep codes. If you do, power off, disconnect power, insert RAM, connect AC and reboot. If system boots, power off and add hard drive. If it doesn't, replace the motherboard.
If the system boots with RAM, but fails to boot with HDD, replace HDD 1st.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
