Vizio P50HDTV20A 50 in. Plasma HDTV Logo
Posted on Sep 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red line down middle of television - Vizio P50HDTV20A 50 in. Plasma HDTV
  • CoppellTVRepair.com Jul 16, 2012
    If it's a single thin red line then there's nothing you can do about it. It's just an address driver buffer transistor gone bad and since those are embedded in the plasma display fabric you can't repair them.
    if it's a wider line then you may want to look at the following:http://blog.coppelltvrepair.com/2010/10/...
    P50HDTV20A is known to come in two completely different implementations - one is a Samsung license and the other is an LG license.
    The above link is relevant for the LG based version of P50HDTV20A.
    Hope this helps!
    bobby @ coppelltvrepair
Calvin Williams
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on Sep 19, 2011
Calvin  Williams
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
9288
Points
147
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
  • CoppellTVRepair.com Sep 24, 2011
    Make sure you do NOT put pressure on a plasma screen TV!
    That would only work on LCDs.
CoppellTVRepair.com
Level 3:
  • Vizio Master 778 Answers
CoppellTVRepair.com
Vizio Master
Level 3:
Answers
778
Questions
0
Helped
396395
Points
1847
There are several different possibilities.
if you have image on the screen other than the vertical line then it's likely the plasma display itself. There are some ICs in it which somtimes go bad and when one does it may short the whole section or just damage the image for a few inch wide vertical line (or a hairline, depending on how it fails).
Another possibility is a thick vertical line with no image at the back. That's YSUS failure (rarely) or buffer board failure (usually).
You may want to check this:
http://blog.coppelltvrepair.com/2010/10/vertical-or-horizontal-color-lines-in.html
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Jul 29, 2010
SOURCE: My Vizio television has like a pinkish red screen
i would need more information but it sounds like your panel has gone bad. the panel is not a part worth replacing due to its price. it will cost you the same if you purchase a new tv.
Red line down the middle
Well it can indeed be fixed, i see these from time to time in my, shop, however there are quite A few "Causes" for this "Symptom", It's my professional opinion, that you get a "Quote" from a Sony, head office recommended service center, and ask for a "Quote" for repair. This way you will be able to make an informed decision.
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Red line on TV screen.
The LCD panel is defective...sorry I have to give you bad news.
Thin red line down the middle of screen
Enter muye 1 / 8 /3
it puts you into convergence mode and clears out all bad magic foces data.
then run perfect focus to save new data.
hope this helps
daniel
1helpful
Red line on screen
yes it can be fixed , it is a IC chip failure or another component that is in the circut
2answers
Red Horizonal Lines
Good Day;
You may have bad picture tube or convergence problem. Good Luck, big IRIShH.
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
