Drain it using the drain valve on the bottom-side of the inlet/outlet header; make sure the heater sits level or slightly tilted down on the header side. You also need to drain the water tube that feeds the pressure switch inside the heater cabinet. Turn off the gas and power off the circuit and you are done. If you cover it DO SO LOOSLY! Wrapping it tightly and not allowing air to flow thru will lead to rapid rusting of all the sheet metal.
John
