First of all I can not see what the other experts had suggested. So what are the htings you have already tried? Can you still close the carriage? If you can, close it then smack it with medium force then try opening it again.
Hi jaslavitt
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
What you can do now , is remove the batteries first and then put them back in and then which you hold the camera in a position as if you are recording the video , press the eject button and the tape can come out, it gets stuck sometimes , however when the above process is done properly it works fine.
Hope this helps ...:) In case you have any queries , feel free to contact me.
Welcome to Fixya
Sounds like there is a problem with the mechanism. Try this one first. Remove the battery and AC power to "reset" the camera. Put the battery back in and hold the camera in the upright (s if you are using the camera to shoot video) position then
"Open/Eject" latch.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Turn on your printer and lift the access door. The print carriage will move to the center.
Thanks for the quick reply, but...it did not work. The carriage is half way out with the door open. Nothing but a few beeping sounds
I saw that fix on your website before I paid. It did not work.
As stated, The carrage came half way out with the tape still inside and it is stuck in that position. No movement either way.
