Question about 2wire (1000-000057-000) Modem
Flashing dsl light
How long does it take for the dsl light to stop blinking and satbilize after powering it up
and also should the dsl light flash if there is active internet connection?
    Scholar:
  • 70 Answers
The DSL light flashing on the modem is natural for it means the device is synchronizing. But if the DSL light continues to flash, you have to wait a while before connecting, it shouldn't take more than a minute. If it does, you may need to contact your service provider because that is uncommon whether there is active Internet connection or none.
Posted on Sep 17, 2008
SOURCE:
Other lights blinking but internet light is blinking for 2-3 times them off all the time so I am not getting internet
On most DSL modems, normal light states are:
Power - Solid
DSL - Solid
Internet - Solid or flashing quickly when data is being transferred.
Ethernet - Only on and flashing quickly if cable attached to it and an active device
Wifi - Solid or flashing with active data transfer
Sep 24, 2014 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Is my modem is blinking is this normale
The POWER light should be 100% on.
The WIRELESS light should blink -- hunting for wireless devices, and communicating with them.
The NETWORK ight should blink when there is activity to/from the internet.
May 17, 2014 | D-Link DSL 200 (DSL-200) Modem
Zoom X7n Dsl 2/2 Modem/router/gw dsl light blinks constantly when trying to connect to Earthlink
Try removing the splitter, if it works then you might have a faulty splitter and you need to get it replaced. You might check if you are using the first phone jack in your house / apartment. I remember that was key when i was on DSL. Hope you get it sorted out, not having a working connection is very annoying.
Nov 18, 2013 | Zoom X7n Dsl 2/2 Modem/router/gw
Zoom X7n Dsl 2/2 Modem/router/gw DSL light will not stop blinking - trying to connect with Earthlink
Earthlink is not your local telephone company? You would need to contact your local service provider. If earthlink set up your DSL thru your local telephone company, you may have to have them contact them. Does your local phone to you or do you subscribe thru what they call a CLEC?
My at&t Motorola 3360 has every light blinking but is still working. The Power and DSL are continuously blinking red and the ethernet, internet and activity are all blinking green.
Here's the thing...if the modem is unplugged, and you press the "Reset" button, or any button, nothing will happen because the modem is UNPLUGGED.
When you plug it in again, there is usually a few minutes or so during which time the lights will blink. Eventually, when the DSL connection is established, the blinking should decrease. But, there will always be some blinking going on to indicate that data is being transmitted.
If the "Ethernet" light is blinking, then a computer that is plugged into the router is transmitting/receiving data. If the "Wireless" light is blinking, then a computer that using a wireless connection to the router is transmitting/receiving data.
If a red light blinks, then that usually means the DSL connection has been broken. When that happens, for whatever reason, the modem will automatically begin its initialization routine and will continue to do so until connection has been established. During that time, LEAVE IT ALONE.
If you uplug the device, or if you press ANY button while the device is attempting to correct itself, you can cause permanent damage.
So, you are correct. It's not a problem. I'm sure you've heard the phrase "If it's not broken, then don't fix it." There's a lot of truth to that.
I hope this helps.
Randy
Dec 01, 2012 | Arris 3360 AT&T DSL Modem - -
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
Hello
Does the DSL light come on at all when the modem is powered up?? If not, then it looks like the modem is bad.
When the modem is first powered on, all of the lights should come on and then go off after a few seconds. The power light should then begin to blink while the modem does a self test. Once that is done, the DSL light should come on and begin to flash red. If it senses a DSL connection, it will change to flash green until it has established a DSL connection. If it does not detect a DSL connection, it will continue to flash red. If the light does not flash at all or if the power light continues to flash after a minute or so, then the modem is most likely bad.
Let me know if you need more help. :)
Jan 12, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Constantly blinking Activity light
Well, you are very correct with the activity light blinking and the increased blinking except the fact that modem will encounter a problem in future...
The 5 different lights on your modem namely Power, Ethernet, DSL, Internet and Activity have their own indications and explanations.
1. The Activity Light indicates the amount of activity that is takin place on the computer on the Internet though the activity might blink even when you are not browsing. This can be explained by stating that the computer constantly keep sending signals  about it being connected to the internet and any other acknowledgements..
So, you've got nothing worry about unless the Power or the Ethernet or the DSL or the Internet light Blinks....
Cause they are the resultants of a fried modem(check for the adapter), faulty LAN connections, interrupted Dsl line and the account verification failure indications respectively.....
Dec 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
DSL light flashing constantly
I had the same problem to begin with. Here is what the Zoom helpdesk suggested:
"To force the dsl light to stop blinking, please follow these steps.
1) Open up your web browser and type 10.0.0.2 in the address bar. Type in the the username and password to log in to the modem.
username: admin
password: zoomadsl
2) When you get to the address bar, Click on advance setup.
3) Click on ADSL Configuration.
4) Change the standard to G.Dmt and change the activate line to Start.
5) Save changes and then write settings to flash.
Within a 1 or 2 minutes, the dsl light should go solid."
This worked for me. Good luck.
Mar 24, 2008 | Zoom X6 (5590) DSL Modem (55900003)
2wire (1000-000057-000) Modem Logo
790 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
