SOURCE: When I connect my model KW-SA235 to my PC and TV,
PC to TV KW-SA235
Even though I have a hi res. 40 inch TV from Sony the quality of the picture from the PC to TV is far inferior to the small screen on my laptop. I can read all the shortcuts in the laptop, but they are completly unreadable on the TV.
I have tried to use the adjustment for increasing the sharpness, but it hardly changes. I tried to use the AV cable instead of the RCA one and although the definition was the same it went black and white,
The instructions tell me to change the computer resolution and refresh rate the pictures are so small that even after scanning then at 600 bpi I cannot see what is on the pictures of the screen.
This is far below the quality that I was hoping for and I am really disappointed. Even copying old videos from the 50's I am getting better pictures than this. There must be a better way of getting the very good screen results on my laptop, - an almost brand new Toshiba , onto my almost brand new Sony DVD Recorder. HDI to the Telly works fine but there does not seem to be a HDMI input, on the DVD recorder only an output.
The inputs available are RCA, AV which the laptop does not have, a scart and a USB which I do not seem to be able to use. So how do others do this. I have a lot of things on a 1.5 terabyte hard disk that I want to put on DVD.
Any comments would be welcome. Thanks George.
The KA-SA235 is not optimal with Hi-res digital TVs as the max resolution output is 1024x768. It's better suited for SD TVs using an NTSC or PAL signal.
