Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
I installed the lexicon lambda with the disk provided but when i put my mic on the mic input it doesn't record... what should i do? please help!
    Master:
    Sergeant:
  • 447 Answers
First thing to do is check your sound and audio settings, goto control pannel,then, sound/audio setings and see if everythings set up properly
Posted on Sep 22, 2011
SOURCE:
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Mar 05, 2013 | Lexicon Alpha Personal Recording Studio
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
I Installed the Lexicon Lambda and followed all of the instructions to the letter. I can hear sound out with no problem, but when I record, it records from my laptops internal mic. Thus, everything in the...
You will need to go into your sound properties, you can do this by clicking on the speaker Icon thats down by the clock (lower rights hand side of your screen) that should bring up sliders for everything.
Their is also other options and advanced options you may need to enable that could be specific to your devices. but the main thing here would be for you to disable the one mic and enable the one you want and also possibly lower its sensitivity levels.
Apr 17, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Dec 26, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Cubase software lexicon Lambda and IMAC
Hey robert I can help. What model Imac do you have and Lexicon do you have?? Please let me know.
Feb 10, 2008 | Lexicon Lambda Usb Desktop Recording...
Distortion
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
192 people viewed this question
Top Lexicon Computers & Internet Experts
Tony Raia
Alun Cox
Thomas F. Schneider
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
