Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
Posted on Sep 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I get a cylinder head for a clarke champ air compressor model #AC2001B?
John Trevino
Level 3:
  • Clarke Master 1,420 Answers
  • Posted on Sep 19, 2011
John Trevino
Clarke Master
Level 3:
Answers
1420
Questions
Helped
1012178
Points
3200
This company in liquidation in the US, however many of the same compressors are available in the UK re-branded with different model numbers/names (alpha name instead). Go down the list opening manuals until you find similar looking parts. You may find same pump/motor components on a different tank, however use manual information as needed. China made compressor as yours will be sold by many different retailers under different names. Look on ebay first "searching pancake" compressor for likeness. The manuals listed below should clue you in. Good luck.
http://www.clarkeservice.co.uk/product_manuals/air_compressors.shtml
Testimonial: "Thank you for your helpfull information. You have answered my question and saved me lots of time and trouble."
1helpful
Bostitch AB-9048025 What's it made of?
Bostitch calls the AB-9048025 a non-return valve, most compressor companies call then tank check valves. All the check valves I've worked with are brass with a spring loaded, plastic valve to hold the air in the tank when the pump shuts off. Many are interchangeable with a little line re-routing. You can find the AB-9048025 on sites like www.ereplacementparts.com. Also, on that site, you can put "tank check valve" in the parts search box and get a list of valves available and most have pictures of them so you can see what you'd be working with.
Looking for parts for a Clarke air compressor,model AC2002
try going through machine mart in uk they are main agents for clarke machines
try machine mart in uk they are main agents for clarke machines over here
I have the clark 4 gallon compressor Model #AC2001B. When I pull the on switch the compressure attempts to start. It runs slowly for a few seconds then stops. I do not know why this occurs. Thanks
Hi I know these need to be very high powered so try plugging it in direct to the mains not an extension lead or use the mains from the house not a garage or outhouse hope this works!
My air comp. ac2001b will run fine shut off then wont start up under pressure but will if you drain air out of it
There is a differential between the shut-off and start pressures of about 20 psi and these pressures are adjustable on some switches. What the switch must do as well is relieve the pressure on the compressor head so that the motor does not try start against a load. You shoud hear the pressure relieving when the compressor shuts off, if not you need to rectify this problem, otherwise check the pressure that the motor cuts in at and set it or replace the switch.
I need a replacement part for my Clarke Champ AC2001B. Where do I look?
Try this PDF link.
If you need more help come back.Post / thumbs / testimonial are welcome!
Top Clarke Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
