Could not locate this model but this may help:
Power up the Player, press pause;
Type in 314159 on your Remote Control's Keypad;
This should bring up the Region Selection Screen;
Select the Region (1-6) that you wish to view on your Remote Control's Keypad, sit back, and enjoy ;-)
Two important features with this player.
Firstly, in addition to the first hack listed above, instead of choosing a Region 1 through 6, you can choose to set it Region 0, or region free. This means you will not need to change it every time you put in a disc of differing regions.
Also, if your TV is not capable of both NTSC and PAL playback, you can adjust the format of the DVD player signal by flicking the System Select switch on the rear of the player. Without changing this, the region free hacks listed above may not display correctly if you are using an older TV
To enable VCD, it works for this model as other LG players:
1. Power on the player with no disc in the drive.
2. Press Pause on the remote control.
3. Using the remote control, key in the following: 1, 4, 7, 2 (the
characters 01 47 should appear on the display) [If your player is a non UK
model, this number will probably be different - don't worry]
4. Press the UP arrow three times (the characters 04 Fd should appear on the
display)
[This number may be different depending on the configuration of your
specific model - don't worry]
5. Press Program, 6, Program, 5 (the characters 04 FE should now be
displayed).
6. Press Enter (the display should flash briefly).
7. Press Return.
8. Power the player off and then back on.
9. Play a VCD!
http://www.videohelp.com/dvdhacks/lg-5500n/4153
